kooch Posted June 18, 2009 Report Posted June 18, 2009 I am putting a second battery in the truck. I will have a Xstatic 4000 for the system and a X static 3000 for the main battery . do i hook the alternator( a 225 Amp) up to the main batt or to the stereo batt? Both batts are under the hood.(for now)
newls1 Posted June 18, 2009 Report Posted June 18, 2009 as long as you connect both batts in parallel (Which you must) it wont matter which batt you connect the alt to. Power will be added to the entire loop. See what im saying. I have dual alts, so I have the 2 0/1ga power leads coming off each alt, and going to the front batt. I then have 2 runs of 0/1ga going to the rear batts. Grounds also...... I love my staffie So anti FACEBOOK it isn't even funny
Jville140db Posted June 18, 2009 Report Posted June 18, 2009 as long as you connect both batts in parallel (Which you must) it wont matter which batt you connect the alt to. Power will be added to the entire loop. See what im saying. I have dual alts, so I have the 2 0/1ga power leads coming off each alt, and going to the front batt. I then have 2 runs of 0/1ga going to the rear batts. Grounds also...... x2 Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
