Hostility Posted June 21, 2009 Report Posted June 21, 2009 i was looking at my saz 3500d yesterday and noticed it said max ground wire lenth 10". and right now my ground wire is bolted to the frame. using about 3 maybe 4 inches under the floor, then comes through then im using almost 12" and it ran my old amp fine. whats the max your ground can be? 10" is really short when trying to ground through the floor to the frame. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
lanman31337 Posted June 21, 2009 Report Posted June 21, 2009 That'll be fine. You try to keep them as short as possible. 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
Hostility Posted June 21, 2009 Author Report Posted June 21, 2009 That'll be fine. You try to keep them as short as possible. oh i know that. but i just didnt know if there is a limit or not? p.s wire is all 0 gauge. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
Gotloud555 Posted June 22, 2009 Report Posted June 22, 2009 i was looking at my saz 3500d yesterday and noticed it said max ground wire lenth 10". and right now my ground wire is bolted to the frame. using about 3 maybe 4 inches under the floor, then comes through then im using almost 12" and it ran my old amp fine. whats the max your ground can be? 10" is really short when trying to ground through the floor to the frame. Yeah! You should be fine. Are You running at 1 @ ohm stable on that amp?
Hostility Posted June 23, 2009 Author Report Posted June 23, 2009 Yeah! You should be fine. Are You running at 1 @ ohm stable on that amp? yes i am. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
sully Posted June 23, 2009 Report Posted June 23, 2009 Your good, especially grounded to the frame. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Hostility Posted June 23, 2009 Author Report Posted June 23, 2009 Your good, especially grounded to the frame. ok cool. thanks 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
