K DUB Posted June 24, 2009 Report Posted June 24, 2009 i got a pioneer premier w3001d2 an im goin to be adding mids an highs which shud i use a battery or capacitor? which wud do me better?
Pioneer~Saturn Posted June 24, 2009 Report Posted June 24, 2009 Battery...for sure And you only listed the sub...no amp...so really in this case you should need nothing. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
95_1500 Posted June 24, 2009 Report Posted June 24, 2009 Battery Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
K DUB Posted June 24, 2009 Author Report Posted June 24, 2009 Battery...for sureAnd you only listed the sub...no amp...so really in this case you should need nothing. im gonna hook it up to an hifonics amp...Hifonics BXi 1210D to be exact
Owners1 Posted June 24, 2009 Report Posted June 24, 2009 Capacitors don't do much. Maybe if you get a fancy one it will tell you the voltage. But then again, thats about all it does. Hummer H2 ( Crossfire XS V2 15's (4) Crescendo Audio BC 5500s (16) Crescendo 6.5's, (16) Crescendo Tweeters, (4) Beyma 8" Midrange http://www.youtube.com/Owners1
fischy fisch Posted June 24, 2009 Report Posted June 24, 2009 a sealed battery, not a standard one. x2 do like a batt cap or something small you wont need a godzilla one but you will def need a bat in some casese caps will steal voltage when i ran one i droped to 11.9 now that i took it off im around 12.5 the lowest ive even seend it drop is 12.3v lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
