~digital~bass~ Posted June 25, 2009 Report Posted June 25, 2009 I was telling you he does not mean hifonics and he means Hypnotic. I dont know the site so I told you to look it up. Car Audio + Bodyboarding/Longboarding = LIFE!!!
basshead4life Posted June 25, 2009 Report Posted June 25, 2009 the website says this amp is stable at 2 ohm i only have one subwoofer and its wired up at 2 ohm and its hooked up to left channel positive and right channel negative which is how you do mono... because on amp it has chart for mono and points to those two... the only reason the website says its 2Ohm stable is because it is 2 ohm stable when its not bridged Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
~digital~bass~ Posted June 25, 2009 Report Posted June 25, 2009 Damn, what's stuck up you're ass?(It's awsome not awosme.) Hypnotic amps exist. I don't really think it's good quality, and that you could get 1000W RMS out of that amp. But it's better then the amp you got now. I don't think it's worth spending money on that amp. EDIt: i'm a slow typer. Good catch. I dont see a price on their site so just wondering what the price is. Car Audio + Bodyboarding/Longboarding = LIFE!!!
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 the only reason the website says its 2Ohm stable is because it is 2 ohm stable when its not bridged yea well i mean i have it hooked up mono not bridged... or is that the same thing? i only have one sub...
Guest Posted June 25, 2009 Report Posted June 25, 2009 i was wanting to get it then keep the gain low... that amp has enough fusing (50a) that can do about 500rms.
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 that amp has enough fusing (50a) that can do about 500rms. my current amp has 50a though... and its an eclipse professional series...
Guest Posted June 25, 2009 Report Posted June 25, 2009 yea well i mean i have it hooked up mono not bridged... or is that the same thing? i only have one sub... for your eclipse, mono is only supported to 4 ohms and stereo is supported to 2 ohms. running it mono on 2 ohms will add alot of distortion since the amp cannot handle that low of a load
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 for your eclipse, mono is only supported to 4 ohms and stereo is supported to 2 ohms. running it mono on 2 ohms will add alot of distortion since the amp cannot handle that low of a load should i just split the positive and negative coming from speaker into two and then put it back on stereo?
Guest Posted June 25, 2009 Report Posted June 25, 2009 should i just split the positive and negative coming from speaker into two and then put it back on stereo? if the sub is a dual voice coil you can just wire each coil to each channel. running it in stereo. then tune each channel to 200rms or so
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 should i just split the positive and negative coming from speaker into two and then put it back on stereo? or run one voice coil off right channel and one voice coil off the left channel?
