Resin that thing all over, it will add to strength and help with making it airtight. Looks like a nice fun learning experience though!
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
yes Resin it for sure.......the resin wont add strength but it will seal it up...id resin it and add fiberglass matt or cloth to all the seams.....for sure...
My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
Ok here are some pictures during the build...
Shot of the drivers side. All those pieces are finished.
Posted Image
Internal of the drivers side...
Posted Image
Shot of the drivers side in the truck
Posted Image
Another shot of the drivers side in the truck
Posted Image
What I have to work around. Passengers side
Posted Image
First piece on..
Posted Image
Over all shot of progress so far
Posted Image
Passenger side is on
Posted Image
Incriminator Audio: No Chrome, No Carbon Fiber, No BS!! Period....
www.incriminatoraudio.com
Stereo Integrity: Your source for the finest Hi-fi speakers and speaker systems
www.stereointegrity.com
Sound Solutions Audio: Best darn click you'll ever make!
www.soundsolutionsaudio.com
Here is after several hours work with 2 friends. The other box you see is what I had the Atomic in...
Posted Image
The recess will be for the amp. Its to deep right now but I'll fix that tomorrow. The amp will be flush with the front baffle when its done.
Posted Image
Another shot of the amp rack.
Posted Image
Over all I'm a little worried but I'm quite sure my original plan will work. I need to pull it apart and fix a couple "goofs" in it but thats no big deal. I'm DEFFENETLY glassing the next box I try like this!!!!!!!!! No doubt in my mind. After all the trouble this one has caused me I know glassing will be easyer!!
let me know what you'll think so far..
Jon
looks good man. btw, i like the racks in the background!!! lol
Thanks man. Its a display shelf I build for my mom last week. 8' long by 5' high by 9" deep. Thing weighs a ton though!. Almost 2 full sheets of MDF.
Jon
Update!
I haven't worked on it yet today but this is what I did get done yesterday before the DP arived!
Wonder what those are for???
Posted Image
Hmm what idiot puts packing peanuts in an enclosure???
Posted Image
All filled up!
Posted Image
Thats a lot of peanuts!!!!!!!
Posted Image
I forgot what the gross volume was but my net should be 3.6@32Hz
I'm having a little bit of trouble with the port, its not going to be as big as I wanted but owell. I guess I should be happy that I can even fit the DP in the truck let alone get a lot of port area!
Jon
what are the packing peanuts used for?
They are used for irregular shaped boxes, like mine (also used a lot in fiberglass enclosures). They are a easy and fairly accurate way to determine box volume.
What you do is fill up your enclosure with the peanuts. Then take a calibrated box ( box in of which you know the volume, normally cardboard box.) You then take all the peanuts from your enclosure and put them in the calibrated box. You then use the calibrated box to determine how much space you have in your enclosure.
Its an old trick that comes in very handy when dealing with complicated or irregular shaped boxes.
Jon
