4 sundown sa-12's, one jeep 2/23/11 30hz
my past expierence lose the yellow top and get kinetik hc1800 or 2000 and mla module u should be way higher voltage..every morning when i start my truck it hits about 16 volts and during the day bout 14.4
I would lose it if I could get my D3100 :/
  • 1 month later...
Got some HID's 8K for christmas! Here is a vid!
I have a problem with the HID's already though, my driver side headlight flickers then cuts out now when I turn it on, anyone have a solution or is it just a bad ballast or bulb? It was working fine as you can see in the video
  • 3 weeks later...
im loving that port iit is the sex
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 5535 Guests (See full list)
