not to thread jack but i also have a question that relates to this i have two audio pipe 12 inch subs and i guess one of them slid into something in the trunk and ripped the surround in a straight line from the cone to the screw hole on the speaker how would i go about fixing this
Is the surround rubber or foam? If its rubber, I have used inner tube/tire repair patches on the backside of the surround for more severe rips and tears and it works amazing everytime. Never tried it on a foam surround. Carefully spread the surround rip and apply a glue bead to the ripped edges and then realign the rip together. Wipe the excess away. Then apply the patch to the backside, trim to make it fit. This way keeps the front of the surround very clean so all you see is a crack. If its foam, or you don't want to apply a patch you can alway just use rubberized CA glue in the crack and apply a layer on the front and rear of the surround around the rip. This way is uglier but just as effective. Or buy a whole new surround to replace it.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
thanks man i will give it a try i would love to buy a whole new surround but cant seem to find them it is a 12 inch 750 watt audio pipe
Speakerworks.com I have bought a lot of basic surrounds from them. This might be what your after. Take some measurements of your current surround and see if this will replace it. There's a bunch of other sizes too. They include CA glue, instructions and a few small brushes. Speaker Works
It's all gone!
The Celica Build
Feedback
update:
Took the plastic surround off and used the CA glue and glued back down the parts that came off. Damn near bonded 3 fingers together lol. Gonna let it dry till tomorrow and go around the edge one more time with the glue to make sure it makes a nice seal. I accidently cracked the black plastic trim piece when I was taking it off, made a nice clean break tho. Gonna glue that back together, sand the area of the break down, and color match it to my car.
One last question, before I put the trim back on, would it be wise to run a small bead of black rtv around the edge to seal it all up?
1996 Vw Jetta
Crunch 1500watt
1- Kicker 15" L7 @ 1ohm in a 4cu. ft. Ported Enclosure Tuned to 32Hz.
4- 6.5" Menace Door Speakers &
2- Menace super tweeters in the dash
139.11db @ 40hz (6/2010..old amp setup)
  • 4 weeks later...
I had the same problem with the sub surround seperating from my type-r. would "goop" work for this repair? thanks all
I would recommend you spend the $4 for some CA glue. Why risk it coming apart again?
It's all gone!
The Celica Build
Feedback
Just an update, I used this said "CA Glue" and have not a problem since. Holds hella strong too. I've been pounding the shit out of the L7 since I repaired it myself and put it in the new enclosure.
Thanks for the help guys!
1996 Vw Jetta
Crunch 1500watt
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
