Hotdog Posted July 1, 2009 Author Report Posted July 1, 2009 Im not liking the mismatch sub idea .i would run the 2 p2s and be easy on them ,if your smart you will be fine It would just be temporary until I got my other P2's... of course if it sounds like ass then I would just use the p2's by them self Quote (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Decaf Posted July 1, 2009 Report Posted July 1, 2009 (edited) just wire the p2s in parallel to 1 ohm and set ur gain conservatively til you get more subbage Edited July 1, 2009 by Decaf Quote
Hotdog Posted July 1, 2009 Author Report Posted July 1, 2009 just wire the p2s in parallel to 1 ohm and set ur gain conservatively til you get more subbage I could probably get by with the gain all the way down couldn't I... I would think I would not have to turn it up at all. Quote (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
IH8PunkRok Posted July 1, 2009 Report Posted July 1, 2009 dont guess dude. get a dmm and measure the output of the amp. turn the gain until it reaches 22.36 volts and itll put out 500w rms. wire the subs to one ohm and ur done Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Hotdog Posted July 1, 2009 Author Report Posted July 1, 2009 dont guess dude. get a dmm and measure the output of the amp. turn the gain until it reaches 22.36 volts and itll put out 500w rms. wire the subs to one ohm and ur done What is a dmm ... I am not good with abbreviation. Quote (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
