bobonit Posted July 29, 2009 Report Posted July 29, 2009 will they work on a non plunge router too?cuz it says "turn your plunge router..." and i have a fixed router. You probably can, but the only problem I would see is getting it started. With plunge router you can set the pin in the center hole, and then plunge the router down to start cutting. With a fixed base, you would be trying to set the pin in the center hole, but the bit would be hitting the wood at the same time. You could try drilling a starting hole for the bit to go into so you could set the pin and then fire up the router and start cutting. 97 Maxima SE Bunch of shit going in, check out the build Build Log
Gotloud555 Posted August 11, 2009 Report Posted August 11, 2009 Is use this for now on because my bit seem to smoking all time while cutting MDF.. I use jigg saw guide and it work great all the time. Just have to measure or trace a circle and cut. VOLAA!!!
finkster Posted August 11, 2009 Report Posted August 11, 2009 damn thats some jagged ass....sentence structure DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
