GoreMasterCustomAudio Posted July 15, 2009 Author Report Share Posted July 15, 2009 ^^^^^^ would that work???? Quote I can't stop building!!! 4 DC LeveL 4XL 18 Blow Through Re-BuildThe newest addition My '97 Ford Explorer BuildMy First Build 8 RF P1 12's My Myspace Add MeMy Facebook Add Me oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you? If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up. Link to comment Share on other sites More sharing options...
GoreMasterCustomAudio Posted July 16, 2009 Author Report Share Posted July 16, 2009 just ordered the xl's!!!! soon some good http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif Quote I can't stop building!!! 4 DC LeveL 4XL 18 Blow Through Re-BuildThe newest addition My '97 Ford Explorer BuildMy First Build 8 RF P1 12's My Myspace Add MeMy Facebook Add Me oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you? If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up. Link to comment Share on other sites More sharing options...
Forevrbumpn Posted July 16, 2009 Report Share Posted July 16, 2009 Want to know a trick? Build a full size box, with guessed size ports, or bolt able removable ports, and the wall the woofers are mounted to, build about a 6"- 8" lip around it, so it looks like a "I" beam from the side view The outside port of course the largest one, its a high tuned one, about double the inside port So, maybe 150sq port outside, no more than 75sq inch port inside Now the trick, start off with the baffle up as close as possible to the front port, document numbers, peaks, dips in cancellation, and move on drop back another 2" or so, and do the same for right now, your just using some drywall screws or whatever you use to assembly a box to mount the I beam lips to the inside of the box, just look for gains, not over all spl numbers when you find that sweet spot, bolt up, seal up, and fire away Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
Torres Posted July 16, 2009 Report Share Posted July 16, 2009 because a 4th order would be a extreamly small box. and i think it would look fu*king retarted that smalloutput > what a box looks like. if i could fit my 18's in a box with 1 cubic foot with the same output i totally would Quote Link to comment Share on other sites More sharing options...
matt402 Posted July 16, 2009 Report Share Posted July 16, 2009 output > what a box looks like. if i could fit my 18's in a box with 1 cubic foot with the same output i totally would x2. spl isnt pretty. Quote Link to comment Share on other sites More sharing options...
GoreMasterCustomAudio Posted July 17, 2009 Author Report Share Posted July 17, 2009 Want to know a trick? Build a full size box, with guessed size ports, or bolt able removable ports, and the wall the woofers are mounted to, build about a 6"- 8" lip around it, so it looks like a "I" beam from the side view The outside port of course the largest one, its a high tuned one, about double the inside port So, maybe 150sq port outside, no more than 75sq inch port inside Now the trick, start off with the baffle up as close as possible to the front port, document numbers, peaks, dips in cancellation, and move on drop back another 2" or so, and do the same for right now, your just using some drywall screws or whatever you use to assembly a box to mount the I beam lips to the inside of the box, just look for gains, not over all spl numbers when you find that sweet spot, bolt up, seal up, and fire away i love that idea but i have nothing to measure #'s, peaks, cancellations... no of that. and i know no one that has that equipment that i can use or rent or anything. Quote I can't stop building!!! 4 DC LeveL 4XL 18 Blow Through Re-BuildThe newest addition My '97 Ford Explorer BuildMy First Build 8 RF P1 12's My Myspace Add MeMy Facebook Add Me oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you? If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up. Link to comment Share on other sites More sharing options...
GoreMasterCustomAudio Posted July 17, 2009 Author Report Share Posted July 17, 2009 and the pics. some specs its 15.01 cubes before displacement the front square is around well i didnt write it down but i believe around 50hz then the sub wall is 30hz about 2 7.90 6inch aero ports tell me what you think Quote I can't stop building!!! 4 DC LeveL 4XL 18 Blow Through Re-BuildThe newest addition My '97 Ford Explorer BuildMy First Build 8 RF P1 12's My Myspace Add MeMy Facebook Add Me oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you? If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up. Link to comment Share on other sites More sharing options...
GoreMasterCustomAudio Posted July 17, 2009 Author Report Share Posted July 17, 2009 bump for anyone to say anything? Quote I can't stop building!!! 4 DC LeveL 4XL 18 Blow Through Re-BuildThe newest addition My '97 Ford Explorer BuildMy First Build 8 RF P1 12's My Myspace Add MeMy Facebook Add Me oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you? If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up. Link to comment Share on other sites More sharing options...
matt402 Posted July 18, 2009 Report Share Posted July 18, 2009 idk man, looks like a good design. just dont know how it will sound... Quote Link to comment Share on other sites More sharing options...
GoreMasterCustomAudio Posted July 18, 2009 Author Report Share Posted July 18, 2009 idk man, looks like a good design. just dont know how it will sound... im gonna try his trick, but idk how im gonna be able to do it seeing that i wont have the tools or meters. but my ears are still good. lol Quote I can't stop building!!! 4 DC LeveL 4XL 18 Blow Through Re-BuildThe newest addition My '97 Ford Explorer BuildMy First Build 8 RF P1 12's My Myspace Add MeMy Facebook Add Me oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you? If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up. Link to comment Share on other sites More sharing options...
