cars peak?
rebuild your box with a higher tuning
i was still wonting to be able to hit the low notes good but i was going to take my port from 21.5"deep to 16" deep to bring the tuning up to 36hz but will 16" deep give port noise ?
its not depth thats gives port noise its the port area im pretty sure
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
^^^true.......
also You can try moving the box around if there is room
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
Sweeps don't work well imo. Everytime I did a sweep it would say 44 hz in my car. But going through the freq's 40 hz is the loudest. There is 1.4 db difference from 40 to 44.
Try going from freq to freq and see which one is louder.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
ok thanks but when i play anything below 30hz i read better on the meter what can i do to read higher on the meter playing around 35 to 36 hz will making the port shorter help here
yes tune higher. if you're peaking at 27 hz, i'd tune to around the 40's if that trend were to continue. then you'd peak around mid 30's. maybe even tune in the mid to high 40's to peak around in the 40's (again, only if that trend were to continue with the peak:tuning difference).
  • Who's Online   0 Members, 0 Anonymous, 11185 Guests (See full list)
