Mechman Alternators
Um... so i think i broke something
If you want, we can "de-tune" that alternator some so that it doesn't slip the belt so bad.
Unfortunately, your vehicle has a pretty bogus belt setup from the factory, it just can't grip a really strong alternator.
Also, if you keep your batteries on a good charger overnight, it will make the alternator's job easier during the day, just FYI.
I got a question you guys were building an accord wagon around his generation. Did you do anything special to compensate for the "Bogus belt setup"?(Idle pulley) I thought a 6 rib setup would've been able to handle to 250a load :(
Team Sundown
Team XS Power
System:
Car: 1997 Honda Accord
Head unit: Alpine CDE-7870
Amp: 2 Sundown saz-1500
Battery: kinetik 1400 and 2400
Subs: 2 Audioque HD310 D2
bump
6 rib normally does, but the belt wrap isn't great on that vehicle. You can go with a slightly larger pulley to increase surface area, but then you loose a little output at idle. I wanted to do a hood scoop and have two more alts coming up through the hood, but they wouldn't have it. :pardon:
Damn your a crazy man mechman but i like it :rolleyes:
Team Sundown
Team XS Power
System:
  • Who's Online   1 Member, 0 Anonymous, 1666 Guests (See full list)
