sierra mist Posted March 24, 2007 Report Posted March 24, 2007 I don't want to replace the battery post with an aftermarket connector. Should I just use a ring terminal to fit the gauge wire I am using? Might seem like a noob question but I have replaced the battery post in my previous installs. Quote
Eddy722 Posted March 24, 2007 Report Posted March 24, 2007 Put a ring terminal on the power wire and put it on the battery... You don't need an aftermarket post.. Quote
sierra mist Posted March 24, 2007 Author Report Posted March 24, 2007 Put a ring terminal on the power wire and put it on the battery... You don't need an aftermarket post.. Ok, I would normally cut off the factory one and slap on a new one. Kinda don't wanna do that with this vehicle. Quote
dleccord Posted March 25, 2007 Report Posted March 25, 2007 are you doing the big three or something? Quote refs: chode69, superduper
sierra mist Posted March 25, 2007 Author Report Posted March 25, 2007 are you doing the big three or something? Eventually, I probably won't have time to get around to that. I'm starting the install from scratch. Quote
dmanson Posted March 26, 2007 Report Posted March 26, 2007 you can use the battery stock terminal but aftermarket terminals just look better. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
dleccord Posted March 26, 2007 Report Posted March 26, 2007 i highly recommend you using an after market battery terminal. when i upgraded both my positive and negative battery terminals, my dimming was gone; unless i'm bassing for a long ass time. Quote refs: chode69, superduper
Dale Posted April 1, 2007 Report Posted April 1, 2007 i highly recommend you using an after market battery terminal. when i upgraded both my positive and negative battery terminals, my dimming was gone; unless i'm bassing for a long ass time. are you sure it wasn't just your mind playing tricks on you? lol Quote
dleccord Posted April 1, 2007 Report Posted April 1, 2007 nah. not only that, the voltage in the back were within .01 volt instead of .03, so better connection i guess. Quote refs: chode69, superduper
Derrick824 Posted April 1, 2007 Report Posted April 1, 2007 Using a ring terminal will work fine. If this is for a Tahoe (I'm guessing because of your name) then I recommend switching to a dual post battery. Use the side posts for your stock wiring and the top post to add on for you system. Quote
