infinity kappa 6x9's
Rockford Fosgate power 6.5" components in the door..
Powered by a DAT 4125
I have the amp tuned correctly for each set of speakers using a multimeter..
When i turn it up it just smells funny... kinda like an electrical smell..
I do have my 10" infinity kappa in a sealed box.. so i dont think its that.
One time i opened my trunk and saw a littrle bit of white smoke...
What should i be looking for so i dont damage anything...
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
Burnt voicecoils... could possibly be your amp...
But I'm betting its those Kappas...
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Keep looking for the magic smoke coming out of somewhere. How are your sub amp gains set?
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
It's most likely your coils.
And if you have your 6x9's in the stock location then there's most likely an opening to your trunk under them so that means your Kappas are the ones that are out, and that should explain the white smoke in your trunk.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
im assuming this is bad for the 6x9's???.... lol
What can i do?
I know the kappas are rated at 2ohm.. but i have heard that is just infinties way of advertising them better than they actually are..
Should i set the gains as if they were 4ohm instead of 2ohm?
All i can really do is turn the gain down right?
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
What can i do?
It's not bad, it's terrible.
That might have cost you a set of 6x9s.
Do you have all your speakers connected to that amp?
And does your amp go into protect?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
The amp has never gone into protect mode... as far as i know.
Kinda worries me though, i have had a few quirks with the DAT amp so far...
Can you look at a Voice coil and tell if it is burnt?
And what should i do to prevent any further damage.....
This is lame, lol. I know i have the amp tuned correct because i DID NOT want to blow any speakers... I guess that doesnt matter...
Another thing to note... i have some engine noise.. (a high pitched whining) coming from the 6x9's.. it is RPM dependent... Its only during acceleration though.. cruising it goes away..
So.. what do i do... im kinda just at a blank to what i am supposed to do now...
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
You need to check your gains and HU features....I'm willing to bet your either majorly clipping them or you have loudness feature or something of that sort.
My YouTube Videos
alpine CDA-9886
I do have the "Loud" feature turned on on the head unit..
The bass is +1 out of 6
The treble is +4 out of 6
Sub is +10 out of 15
Like i said.. i have each channel on my amp tuned using this guide and a multimeter
http://www.stevemeadedesigns.com/board/ind...?showtopic=4382
What do i do?
Edited by JZeFF
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
