where would be the best place to put your ground wire, cause I've tried it all and it seems to make a noise when I hit the gas, not good.......Would it be good to run it from my battery?
What ground are you talking about?
Your amps should be grounded to the frame, and also keep your power and grounds away from your signal wires.
Now your head unit ground can cause whining on all channels since it'll transmit through everything. Mine was doing that a while back. I just took it down and grounded it on the frame with my amps, problem solved
Edited by pstone11
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
  • Who's Online   0 Members, 0 Anonymous, 1754 Guests (See full list)
