adding more HC800s
What up guys ............ anyways in my sig below you can see i already have a kinetik HC2000 and 800. i was thinking about getting 3 more 800s to add to my system along with selling my amp and getting either a RF T2500.1 or American Bass VFL 150.1 ........... the system will be powered with a 225 mechman alt w/mla mod. Do you think my electrical is strong enough to hold up against either of these amps with the 5 batteries total and 225 alt????
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I would run at least 1 more run of 1/0 for positive, and if you are running all your grounds back up to the front, a 2nd run of 1/0 for ground. Then just watch your voltage. if you still get voltage drop, add a 5th 800.
97 Maxima SE
Bunch of shit going in, check out the build
How would you hook them up to the amp? Line all 4 800's in a row and use the neg off on end then the pos off the other end?
Yeh i could just get a couple big batteries but i like my space. i got an 04 Expedition and between the back of my 2nd row and box is just enough space for about 5 HC800s total. i can get a pretty good deal on the 800s so that's why i'm sticking with them and i'll only be running around 3500RMS. Another run of 1/0 would help for sure but i'll get the amp and see how my voltage drop reacts and go from there with adding 3-4 more 800s. Those lil guys are so cute and fit just about anywhere ........... so having plenty of room is an issue ......... might be going with 3 DC lvl 4s before the summer is out too.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 548 Guests (See full list)
