Alright I have just spent the past four hours trying to figure out why my amp has bad feedback. I redid my whole system checked the rcas, changed the spot of the ground. reset everything. After hooking it all back up I get a sound just like before out of my sub. When I start My car I can hear my engine noise through my sub. When I have my car off I get a heartbeat sound coming out of my sub. How do I fix this? I have had it with car audio and need help. Could it be my deck?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
I am running my power wires on the driver side and the rca and remote on the passenger side
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
as you can see from my sig it is a kenwood it was like 70 bucks any suggestions on what one I should use?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
nope
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
loosen the amp from the panel and lift one side up. I had a similar problem with my SAX 100.4. They make the amps with such close tolerances that the bottom touches the components and makes the noise. At least that was the problem for me. I just put washers under all four spots to lift it up and it works great now.
my rcas are rockford fosgate got em at best buy and my system is in my sig
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
