8v furys 1990 vw jetta coupe (work in progress)
Past couple months, been having use the money I had saved up for my new system to repair, replace and fix stuff on my car.
Pushing it to the limits. Want more power.
  • 2 months later...
Seems like every time, I have money for stuff for my new system, things break or need to be replaced on my car. Today, my sub decided to die on me. Time for a new sub.
i know how it is man. everytime you have money, it seems like something always fails on you. just had to replace an injector on my car couple of weeks ago, fun times with that. but good luck gettin everything fixed. i also saw the gps, kind wish i had one, but store maps are fine by me.
formerly known as Blue86f150
this sux camel dicks
  • 1 month later...
Car has been sold. I am getting something different and might even have enough money left over to put a new system in.
  • 2 years later...
Update:
Bought the car back from the person I sold it to. The car was not running when I bought it back and the system was stolen while the car sat in front of his house. After a few parts replaced and fixing some stuff the car is running again. Still need to do some more work on it and replace some parts and she will be good to go. Here are pictures as it sits right now.
Tomorrow, if my friend doesn't get called into work, we are heading over to put on the new oil filter, new drain plug and oil filter. Then fire the car up again and hoping nothing goes wrong. After that doing some cleaning and installing the lower dash.
  • 1 month later...
Car is running again after changing the oil, oil filter and hooking up the battery. But the car has been put on hold again due to my ankle injury, the car needs some more parts to be able to drive on the road again and being on limited funds cause of work comp.
  • 10 months later...
Its been a while since I have update this thread, go alot of stuff done to the car since last posting.
It made it from Placerville to my parents house no problem on the back of a flatbed tow truck. Big thanks for Toney for helping today.
Heres toney steering the car for the tow truck driver:
Loaded up in Placerville and about to take off.
Here it is now sitting in back of my parents house.
Battery is charging right now and still need get some gas to let it run. Tighten down the loose nut on the shift linkage and now need to adjust the shift linkage.
Installed the side trim.
Before:
After:
Installed dash bezel and driver side lower dash:
Before:
After:
Installed passenger side lower dash:
Before:
After:
Car is running again. Timing and idle need to be adjusted and then smog it. Thanks to kenny for the parts today, so that I was able to finish my to do list today.
Found a major vacuum leak. Used a rubber elbow from a chrysler to fix it. Car runs and idles better.
Swapped the stock door pins to Wolfsberg edition ones (found these in one of my boxes in the storage shed.
Stock:
Wolfsberg edition ones:
installed Mk3 battery cables (still have to add connectors and heat shrink to factory wires to attached to terminal), set up the MK4 factory distrubtion block to bet hooked up to terminal.
Ring terminals soldered to wires and heat shrinked. Wires connected to terminals.
These next photos are for people wanting to know how much taller engine then a stock engine. Also a picture of the breather block off plate.
Sold the Rota wheels and now the coupe is rolling on sebrings (have to get the correct size tires), swapped out the big bumpers to small bumpers.
Reinstalled factory shift boot, installed the vw/audi shift knob that I got from Kyle and installed the clip for the gas door to have a working factory locking gas door
Here is with the wheels cleaned up a little bit and the center caps installed.
Almost done with the early trim conversion on the trunk. Big thanks to Kenny for the parts. Still need a early lock trim, since is broken. Still need to remove the remaining double side tape from the factory for the late style trim.
Shifter alignment tool arrived and was able to adjust the shift linkage.
Bosch wr7ds spark plug arrived today. Will be installing soon.
Lock trim arrived today and installed it.
