messed up my 45s =[
so i put in 2 of my 45 degree angle pieces in the inside corners of my box last night and i didnt have enough pressure on the bottom of the 45s, so they didnt make a smooth seal with the wood. its glued in there good, but where the 45 meets the box, theres a small opening (maybe 1 or 2 millimeters). is it gonna be fine or should i rip em out? and if i were to rip em out, how would i take them out without fucking the rest of the box up? its a 4 cube ported box tuned to 34hz for a daily application for a 15 inch fi bl.
fill it in....
you could drill a small hole and fill it with spray foam...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
liquid nail over that sum bitch and then throw some resin and mat over it ;) i had the same problem on my buddys box but that worked like a champ for me.
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
lil bit of glass and or bondo...
NoFearX18 said:
trainman0978 said:
  • Who's Online   1 Member, 0 Anonymous, 12903 Guests (See full list)
