Iam just curious, why did you spend the extra couple $$ on the shielded speakers, over just getting standard ones? Going to pop them in a home set up later?
Ive done so many fiberglassed doors, but one thing I found out... KEEP THE TOP portion of the door intact, and resin down ward... Here was my attempt at 6- 6x9s per door in a Lincoln Navigator 24 6x9s, with 2200w/rms of fosgate power to them, this was customers choice, not ours, plus he wanted 4 tweeters per front door, when the 6x9s were 4 way... But anyways, my point is its easy to do doors when you keep the top part on, and work down ward
Posted Image
Posted Image
Posted Image
That is before vinyling ofcourse, I dont have final pics, because I got jacked for money there at the shop, and quit before the final pics were
Posted Image
Posted Image
Posted Image
yaa if you notice at the top part of the board you'll see little cut outs, thats for the orginal 1 of 2 orginal peices tat i am reusing, the other is the handle/arm rest.
i'll start the streaching of the cloth later today,I've got chemistry, and work to take care of first
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
just did a test fit,, theres no way possible for me to have the the sub up front unless i did it like before, i think i'll just use both 8's in the rear, and the tweeter and mid in the door. KISS Keep it simple stupid
fuse box is behind one, and its a stick shift very little room i looked at it, too iffy. it would be really close to my clutch foot. i would hate to put my foot through a subwoofer
I plan to use the mid range in the door, alot with the memphis tweeter i have in the kick, and use a fiberglass box in the rear for an 8".
I was given an yahama 5.1 amp/ processor yesterday, so i need to work on an HT setup too..... also i know i need to do some engine work, alittle smoke, and a little oil buring.
Tweeter in the kick?? Bad idea. Mount it much higher up. For one thing, you can't have any obstructions (like a leg) between a tweeter and the ear, or it will sound verry muffled. Mount the tweet in the A pillar FTW
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
kick so it will make the path more equal
Maybe so, if you never listen to music with yourself in the car. You'll find yourself angling your legs in an odd way so you won't block the tweet.
Subwoofer Wall
