big 3. engine block to chassis?
when doing the engine block to chassis ground does it matter what part of the engine block you do it from? i dont know where my stock one is so i dont know
where i should put it. I have plenty of spots on my engine where a screw could go. Any suggestions?
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
yeah i dont think it matters... the one on my tacoma is on the intake manifold....
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
The absolute best place to put it would be on one of the alternator mounting bolts. Other than that, anywhere on the block would be ok. Right now mine is on the intake manifold (it was easy to get to) but I'm going to move it to the alternator mount when I change out my belt, but thats just because I'm anal.
97 Maxima SE
Bunch of shit going in, check out the build
Just connect the wire the alternator bracket to chassis. That work great most of the time. Just make sure the wire don't end up touching the moving belt and use grommet.
  • Who's Online   0 Members, 0 Anonymous, 638 Guests (See full list)
