My dash kit is supposed to support a single iso din, double din unit or 2 iso dins. The install instructions show a rear support is used. Of course, there are no rear supports in the dash kit. I had a kit I used in my Canyon and it worked well.
With the 2 iso din unit in the kit for my Tahoe, the units are right on top of each other. What else can I use to give them a little space between each other?
Canyon kit
My Tahoe kit
Hey man, I am sure you know this but you are supposed to take off that plastic part on the lower deck that is on the back of the player. just take that screw out, it is for security reasons, if you already knew that then I was just making sure hahaha. Why do you need more space?
Damn Thiefs
It's not really a space issue. I'm going to grind away some of the plastic. Most of the problem is the big volume control button stops the face from opening all the way. Plus, the flip out screen needs enough clearance to retract. Otherwise, it will hit the top of the kit and go right back in.
I would say dremel it out some and if not move the top flip out and make new screw hold for it!
Sounds like I'm going to customize a generic kit. It should be done this weekend.
give me your cars year make and model and i can get you a dash kit shipped to your door for a lil fee (plus the cost of the kit itself)
if you wanna go that route i can do that for ya....just PM me
NoFearX18 said:
trainman0978 said:
why don't you just drill holes in the sides of the tahoe kit so that you can put screws threw it that hold the deck in place... and then cut like a 1/4" stip of abs plastic to seperate the decks
1st place circuit city car/spl show (maplewood,MN) 2006
146.6 dB's with 2 12" L7 and 1606d brutus
