Fi Car Audio
i have a 15 inch bl hooked up to a hifonics brutus 1608d yesterday it just turned off in the midle of play... i had it on loud but was not pushing it the amp still turns on normally and is fine and has power going to it i hooked up another woofer just to see if it was the amp and it played fine, so its my 15 inch fi bl thats the problem anyone have any ideas? thnx..
check the BL speaker wiring. push down on the cone evenly to see if theres rubbing noises. use a multimeter on the coils to see if they read either close to 1 or 2 ohms
Take a 9 volt battery and do a "pop" test by hooking wires up to the terminal blocks and touching the + and - respectively on the battery.
Authorized Ascendant Audio Dealer! Message me for information.
If you can't explain it simply, you don't understand it well enough -Albert Einstein
"I have a plausible excuse for not liking you. And you know why."
I love this trick. haha
Bills
KwB
Team DC Audio Midwest captain
Check the wiring at back of the woofer. I might came loose or not. If that seem fine then try another woofer and see it work on that amp. IF does then something might be wrong with the BL sub.
