fox_racin4 Posted July 30, 2009 Report Posted July 30, 2009 you may not see "much" of a gain but it probly wont drop as bad as what it did befor the big 3 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
J00bles Posted July 30, 2009 Report Posted July 30, 2009 sanding those grounds (as mentioned) should yeild in a better voltage. my big three game me a solid .2 volts constant and my batteries maintain a better voltage during music. try the grounds and see for sure 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
Noobtastic14 Posted July 30, 2009 Report Posted July 30, 2009 I didn't GAIN any voltage- at least not on my little meter. but efficiency when it dips drastically increases, my voltage would FIGHT to stay at that mark instead of dipping and rising slowly like it did before the big III -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
fox_racin4 Posted July 30, 2009 Report Posted July 30, 2009 i gains about .8 volts and theres not much dipping under 13 well.... i dont let it i got a small 75A alt so... doesnt charge up all that great witht eh system on hah 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
BulletInjection Posted July 30, 2009 Author Report Posted July 30, 2009 i gains about .8 volts and theres not much dipping under 13 well.... i dont let it i got a small 75A alt so... doesnt charge up all that great witht eh system on hahyou saw the .8 on your needle though right? My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
fox_racin4 Posted July 30, 2009 Report Posted July 30, 2009 the needel is accurate i just cheacked it with a DMM needed is reading roughtly 14.1/4 and hte DMM is saying 14.21 while idiling so... lol pretty close 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
1992Chevy K1500 Posted July 30, 2009 Report Posted July 30, 2009 you saw the .8 on your needle though right? Not necessarily. Stock voltmeters aren't accurate below 1 volt. As in, they don't pick up any voltage changes below 1 volt. Some might, but it's not a guarantee. My comp setup (Not bad for what it is): HP Compaq Presario V6120US laptop with: 15.4" widescreen AMD Turion 64 X2 1.6GHz processor 2x1GB stick DDR2 SDRAM (667 Mhz) Seagate Momentus 500GB SATA HDD 128MB shared video memory Windows 7 Home Premium 64 bit 12 cell Lithium Ion battery (actual battery usage time: 6 hours) What it does: On a USB 2.0 Wireless card
amazinblazin10 Posted July 30, 2009 Report Posted July 30, 2009 if you have side post terminals on that battery you might try and hook them up there, i think i read somewhere that you don't get maximum current flow out of top post but i could be wrong 1997 Dodge Ram Van 2500 Big III addition with 1/0 awg wiring all throughout Lightning Audio Strike S4.1000.1D Jenson XA2250 2 - 12" Mtx Jackhammers JH55 3ft cubed box sealed under the rear bench seat Pioneer DEH-P6000UB head unit MB Quart FWA 160 components up front
fox_racin4 Posted July 30, 2009 Report Posted July 30, 2009 you saw the .8 on your needle though right? will also add i installed my own volt meter in the car as it didnt have one stock 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
BulletInjection Posted July 30, 2009 Author Report Posted July 30, 2009 will also add i installed my own volt meter in the car as it didnt have one stockspeaking of that, what did you wire everything up to? The stinger voltage meter wires are really short so did you just hook everything up to your h/u or crimp longer wires My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
