Problem with Alpine 9886
there is a button to the lower right of the volume knob.
hold it for a couple seconds. then go to general. then scroll down to "power ic" and turn it on.
the button is the one with the F on it (says setup under it) to the right of the "go back" button.
http://www.alpine-usa.com/US-en/products/p...ng=en&tab=A
in the settings it should say power ic or something close, just turn it to what its not on
^^^^^^^ damn your quickness!!!! lol jk
hope it work bud
Edited by sphinxbccp
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
it did not work. i am going to hook up my memphis amp and see if it works then....
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Some decks will shut off the internal amp when connected to an external processor like an imprint or H701. make sure this setting is not turned on without an external processor. Sometimes it's a manual switch on the underside / back of the deck it's self. Other times it's in the setup menu.
yea when i first hooked it up i noticed those switches on underside and i switched them all back and forth but that still didn't work...
well i just went and bought an ipod and hooked it up.
same shit as CD mode. you can see its playing the ipod but there is no sound.
i'm still waiting for a response from the seller on ca.com....
Under the rear deck of your car is a factory amp and you have the power antenna hooked up to the factory amp turn on as the remote wire. Make sure that the wire going to turn on your amps or the blue wire on the harness you bought for the car has the blue/white wire hooked to it from the alpine not solid blue that should fix the problem
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
im not using any amps.
but why would the radio work fine and not the cd or ipod.
check the connections on your harness and see what wire is attached to the blue wire on the harness you bought for the car if its blue to blue then change it to blue/white from the alpine to blue on the car harness and you should be all set like I said you have a factory amp under your rear deck it is a silver box looks like it is one big heat sink
edit- the reason it only works on tuner is because the blue wire you have hooked up from the alpine is the power antenna it only has 12v while the radio is on tuner
Currently in car
  • Who's Online   0 Members, 0 Anonymous, 1307 Guests (See full list)
