k3n12ock Posted August 1, 2009 Author Report Share Posted August 1, 2009 Thanks for all the replies. Tomorrow i'm going to do the big 3 and go get another cheap dmm and if i still have voltage drop i.m going to put the soundstream back in until I can cop some 0/1 ppower and ground wire. i read that there are things that take in 0/1 wire and exit into 4gauge or something like that. Any know where i can get something like that? Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
WaTTz305 Posted August 1, 2009 Report Share Posted August 1, 2009 yeah go ahead and do the big three its deff voltage drop it was happening to me and i didnt do the big three and now im lookin at a dead rockford Quote Link to comment Share on other sites More sharing options...
LoudF150 804 Posted August 1, 2009 Report Share Posted August 1, 2009 you should prolly put ur capaciter back in Quote 1997 F150 2 12' Diamond Audio Subs 600.1 Diamond Audio Amp mids/highs Jenson 760 amp 2 Pioneer 5 way 6x9 4 pioneer 3 way 5x7 2 Power Akoustic Tweeters. + more to come Link to comment Share on other sites More sharing options...
enemyofsilence Posted August 1, 2009 Report Share Posted August 1, 2009 Thanks for all the replies. Tomorrow i'm going to do the big 3 and go get another cheap dmm and if i still have voltage drop i.m going to put the soundstream back in until I can cop some 0/1 ppower and ground wire. i read that there are things that take in 0/1 wire and exit into 4gauge or something like that. Any know where i can get something like that? here ya go LINK these things work great. but get that big three done Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
k3n12ock Posted August 1, 2009 Author Report Share Posted August 1, 2009 Big 3 tomorrow. Whoop. you should prolly put ur capaciter back in Yeah I'll try that first before the big 3. here ya go LINK these things work great. but get that big three done Thanks man. Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
Kvo_8 Posted August 1, 2009 Report Share Posted August 1, 2009 this happened to me and im running a ed nine.4 and a jl 1000/1...i was using 4 ga wire and it would cut out even if i turned up the volume past like 10/35 on my alpine...but once i upgraded to some knukonceptz 0 gauge fleks wire, everything is fine, i can crank it. also have the big 3 done and a yellow top up front. so new power wire gets my vote Quote Alpine 9886 Polk Audio 6.5 Component db series Elemental Designs nine.4 JL Audio 1000/1 DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz Clarion EQS746 Stinger Voltage Meter Optima Yellow Top (Front) XS Power 1200 (Rear) All KnuKonceptz Wiring Link to comment Share on other sites More sharing options...
k3n12ock Posted August 1, 2009 Author Report Share Posted August 1, 2009 So I did the big 3 today, still dropping. I'm trying to get a HC1800 now and about 17ft of 0/1 power wire. Alt is too expensive at the moment so I gotta back off that. Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
k3n12ock Posted August 2, 2009 Author Report Share Posted August 2, 2009 Okay. So I upgrades these wires: -Positive wire from alt to battery -Negative wire to chassis ground -Negative wire to engine block ground -Starter wire to positive on battery Still the same thing. I need some wire look though. The ground from the engine block to the negative was touching the block and got hot which caused shorts. Sucks, I know I'm a noob. But yeah, no difference in my system. It still bottoms out. I guess the next step is getting a new battery. Was thinking about a hc1800 or one of these from Got_Bass89 http://www.stevemeadedesigns.com/board/ind...showtopic=49684 Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
k3n12ock Posted August 2, 2009 Author Report Share Posted August 2, 2009 Oh yeah, do you think it could be the subs bottoming out? I mean, I have them wired at 2 ohm and this amp is suppose to be about 1100+RMS. The subs are only 500rms each x 2. Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
