doing the big 3, I need help (pictures)
Alright well I got a 200 amp rewound alternator from Billls Suburban Alternator and now since I have a job, I figure I should do the big 3. So I got 2 ought wiring and I am lost with the big 3.
here is the alternator in the car
Like it says in the pic, I have to do postiive on alt to positive on battery, im assuming the one with the plastic cover is positive?
but which one is the negative cuz I have to do negative on that to chassis...
I have another problem, here are my terminals
the Terminal has bigger holes than almsot all the nuts in my car... what can I do?
and last question would this be a good ground
(factory ground already there)
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
yes thats the correct pos and ground. i have seen others use the other neg. but i did mine on the frame.
edit:use washers or change out you terminals.
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
Thanks guys, which one is the negative? is it any of them?
also which kinda terminals would u reccomend if I change them..?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Any of these should do.
Edit; as long as it is one that acepts 0/2 wire.
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
thanks a ton bro
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
the ones you have shown are both negatives.looking at the pic id use the one to the right it looks easier to access.and its a nut, the other is a bolt you have to deal with. also heat shrink or tape the exposed wire where the terminals are, so no accidents.
/Rant
  • Who's Online   0 Members, 0 Anonymous, 1208 Guests (See full list)
