Got noise in your system? Look here!
Not a myth. Ever hear of an electromagnet? That's what happens when you run power through a wire, it forms a magnetic shield around the wire. My dad has a fork truck that uses 3 12 volt batteries in parallel while just normal use, and 36 volts in series when the forktruck was lifting up and down, tilt in and out. When it hit 36 volts, the wires had a ton of amperage going to them, and became magnetic. High power systems have high amperage going through them, and EMI. Unshielded RCAs will pick it up.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
Absolutely. You want your power and signal away from each other.
Any chance of getting this as a sticky?
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Bump for sticky.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
what do you mean when you say to ground the outer rcas to the body of the hu?? Do you have a pic??
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
he means the outer ring of the RCA. that acts as the negative of the RCA, and the middle prong is the positive. wrap a piece of wire nice and tight around the ring and ground it to the body of the car
Posted Image
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
thanks will try it :good:
4 gauge wiring
Here's a good one. If for some really stupid reason you cannot find a way to run RCA's and power wires away from each other or they have to cross paths at some point, make sure they cross at right (90 degree) angles. It won't completely eliminate noise, but will reduce it quite a lot.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Absolutely. Running signal and power perpendicular from one another if you can't separate is key.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
  • Who's Online   0 Members, 0 Anonymous, 3008 Guests (See full list)
