do it....it can not hurt anything...unless you wire wrong...should help some
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
If you've still got a clutch fan then it makes sense that the voltage drops when it engages. It draws HP from the extra resistance on the crank pulley, this can cause the belt to slip slightly if it is older and cause a momentary drop in voltage from the alt. I would get a smaller pulley on the alt and put a new belt on the car before doing anything else to see if it fixes the problem. Next step is the big 3, then alternator and batteries.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
sounds educational and informational...lol...ima do it...thanks
I wouldnt bother doing the big 3 without upgrading your alternator...Either way your stock alt isnt gona take the beating for long...
on the contrary...i read from an engineer or mechanic or someone (very knowledgeable regardless) that said doing the big 3 is a great idea regardless. sound system or no sound system. it allows for more current flow and he said afterwards when he did it everything in his car would just run smoother. air conditioner ran cooler, etc.
  • Who's Online   1 Member, 0 Anonymous, 3583 Guests (See full list)
