can't get 140+
Higrade
to BL run at 37-38 hz can get u 145 i seen it done
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
Im in the 40's with my 12" Bl on 1300 watts, its allllllllllllllllllll about the box.
BOX and CLEAN power and signal do wonders.
why isnt DC on the sub list?
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
Yeah I would do a single 15 sub and port forward atleast that is what works for me but I use a single dc 18.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
Heh... clean signal in but clip that bastard on the way out :) If you know what you're doing you can gain quite a bit by nudging it a bit into square territory ;)
10.x volts fo' life!
Heh... clean signal in but clip that bastard on the way out :)If you know what you're doing you can gain quite a bit by nudging it a bit into square territory ;)
One step at a time Boon...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
yeah he must have something wrong, In 2000 my mustang had 2 punch 12's on a power 500.1 and did a 142-143 with sealed box at a circuit city slap event , got the two first place trophies to prove it too. won my class in the one-two class
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
Box should be 36 long 17 high and 18 deep
two fi BL 12 and one 6 inch aero port 10 inches long
double the face, go sub port sub all on the same side
whats that tuned to?
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Its not just about his box design, some truck cars are hard to get loud.. Depending how he had the box setup aswell. In my neon I cant have subs up port back, subs back port back and be loud. I have always had to do subs and port both facing into the cabin and have hardly broke the 140 mark. But alot of that has to do with the car itself.
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
yea out of the subs you mentioned the Mayhem should have easily got you over 140.
i had a mayhem 15 on a saz3000d at 2 ohms and was hitting 145+
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   1 Member, 0 Anonymous, 1810 Guests (See full list)
