I used to install for Circuit City, I've seen it happen.
Unplug your alarm and see what happens.
You have just identified the problem, Circuit Shitty...
I worked for them in college and the installers at my store were clueless
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
its called a parasitic drain. its not THAT uncommon. i dont think its you alt. that sounds more like a guy that doesnt know and is trying to guess. we all do that some times. look up how to find a parasitic drain.
now if it is the alarm, is it fixable or is that just something you have to live with? i have a drain as well and i think its the alarm so this could help me as well.
well this was pretty useful and im try this out
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
and this i might just get another alternator
http://www.misterfixit.com/baddiode.htm
Check out my build
http://www.stevemeadedesigns.com/board/ind...mp;#entry717600
4 12" Kicker L7's
1 zx2500.1 Kicker Amp
1 zx650.4 Kicker Amp
All Kicker 1/0 Wire
Headunit Jvc Kw-Nx7000
3 sets of 6.5 Image Dynamics CXS6 series
Maybe where i took my truck to get the alarm installed..... that could of been one of those installers that prob messed up my shit...
Check out my build
4 12" Kicker L7's
All Kicker 1/0 Wire
wow you went their
now as for your problem the alarm can probably founf under the drivers side under dash look for a black box that is ziptied in place no bolted factory module=bolts after market stuff generally=zipties but yes a meter and a little while in the fuse box testing for a drain would be a good way to start
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
Well guys took the truck to my buddy that is a mechanic and we came to find out that the first thing we looked at where the fuses and started to test it and begin to look for the drian and voltage drop.... First one we check we got it right and comes out to be my screen is draining my battery its drawing power even tho the truck is turned off....cause when we took out the fuse the volt meter will go up and when we put the fuse back it would start to drain little by little :D:drinks: .....
Now I'm :censored: mad cause i called JVC cause im still within the 1 yr warrenty of my indash they saying that they can honor the warrenty cause i got it from ebay... but i got it brand new from a company not just some regular person selling the screen.....
Check out my build
4 12" Kicker L7's
All Kicker 1/0 Wire
  • Who's Online   1 Member, 0 Anonymous, 3583 Guests (See full list)
