sixgen Posted August 7, 2009 Report Posted August 7, 2009 Noobish questions i hope some experts can help me with: 1)should i follow the ebp (efficiency bandwidth product) of a subwoofer? 2) I already have a design for a single sub ported, what if i want to make it 2 subs... i double the box volume and double the port? or double the box volume and using 1 port same as a single sub? (2 subs having the same box frequency..) 3) is ABC ( aperiodic bi chamber) better than regular ported for spl? 4) For spl purposes, should i aim for a flat response from my enclosure? ( pls explain reply...) Thank you so much in advance.!
brewer_brewer Posted August 7, 2009 Report Posted August 7, 2009 for a noob. you sure know a lot of terms. anyway. what kind of subs, amp do you have? and what is the max room you have to work with? REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
sixgen Posted August 7, 2009 Author Report Posted August 7, 2009 for a noob. you sure know a lot of terms.anyway. what kind of subs, amp do you have? and what is the max room you have to work with? well i think that these are basic terms and i have a lot more to learn maybe you guys can enlighten me. I'm thinking of using memphis pr 12 dual 4 sub/subs but the epb formula says i use it for sealed. I tried it also on bassboxpro and it recommends a sealed enclosure. so i was wondering if this ebp is important. Also should i double the port diameter if using 2 subs and maintain the length? im trying to fit in a constrained 12" x 14" x 35" ...so not so much space.for amp ill be using a memphis pr 500.1
siucsaluki11 Posted August 8, 2009 Report Posted August 8, 2009 Noobish questions i hope some experts can help me with:1)should i follow the ebp (efficiency bandwidth product) of a subwoofer? 2) I already have a design for a single sub ported, what if i want to make it 2 subs... i double the box volume and double the port? or double the box volume and using 1 port same as a single sub? (2 subs having the same box frequency..) 3) is ABC ( aperiodic bi chamber) better than regular ported for spl? 4) For spl purposes, should i aim for a flat response from my enclosure? ( pls explain reply...) Thank you so much in advance.! 1) you dont have to, if i find the ebp of my subs it tells me to put them in a sealed enclosure, they do quite well ported, need to design a new one though, got some experimenting to do. 2) No, its not quite that simple, there are some calculations you gotta do. 3) aperiodic boxers are more for SQ than SPL iirc. They are supposed to have a damn near perfecly flat response curve if you do it right, which is a PITA from what ive heard. 4) Honestly, the best SPL boxes have the worst response curve youll ever look at, they peak really hard at one single note usually. Thats a dedicated SPL box. If youre doin a daily setup, youre probably lookin for a blend of SQ and SPL, SQL. You want a flat curve for daily/sq usually. well i think that these are basic terms and i have a lot more to learn maybe you guys can enlighten me. I'm thinking of using memphis pr 12 dual 4 sub/subs but the epb formula says i use it for sealed. I tried it also on bassboxpro and it recommends a sealed enclosure. so i was wondering if this ebp is important. Also should i double the port diameter if using 2 subs and maintain the length? im trying to fit in a constrained 12" x 14" x 35" ...so not so much space.for amp ill be using a memphis pr 500.1 Youd be surprised what people know, some of the stuff you know is beyond most beginners, seems yove done a little research yourself before asking questions. That box is gunna be too small for 2 12s ported. 2.5 cubes before displacement is what i came up with for those measurements. Id suggest stayin sealed with that small amount of space. woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
sixgen Posted August 8, 2009 Author Report Posted August 8, 2009 Thanks siucsaluki11for the reply. So Ebp is important if youre aiming for a flat response. im thinking of using 1 memphis pr sub with a total of 3 cubic (woofer and port displacement not included) should i just choose a desired frequency for my box? or use some formulas like butterworth's or keele's for the tuning frequency? I know these can be done with softwares but i want to test this doing manual calculations just to see/hear what it'll sound like. maybe some of you can suggest some ways for me to do this, im leaning on the the sq/spl (sql) approach.
sully Posted August 8, 2009 Report Posted August 8, 2009 try to tune between 32 and 34 hz for daily. The flatter the response the better it will sound over a large selection of music. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
sixgen Posted August 9, 2009 Author Report Posted August 9, 2009 does the position of the sub in the enclosure affect the sound? how far/near from the port should the subwoofer be?
Torres Posted August 9, 2009 Report Posted August 9, 2009 you will want to put the sub as far away from the port opening inside the box as you can.
sixgen Posted August 10, 2009 Author Report Posted August 10, 2009 you will want to put the sub as far away from the port opening inside the box as you can. Ok got it, so if the port is on the left side. my sub would have to be on the farthest right.
