How well do 15s play music?
If I remember correctly he's underpowering those 15's so that may have something to do with it.
15 may be louder but may not be good on sq but hey ftw do what u want its your ride...
so are you trying to say 15's dont have an sq? if thats what your saying then you need to put that crack pipe down. because it's clouding your hearing and your judgement
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
Quick question, will a smaller ported enclosure hit harder than a larger ported enclosure?
2002 Toyota Solara SLE V6
Headunit - Pioneer DEH P3900MP
Door Speakers - Polk Audio db6501 6-1/2" 2-way
Component System
Rear Speakers - Polk Audio db691
Speaker Amp - DD C4b
Sub - 2 12" Alpine Type R's in a 2 @ 33hz
Sub Amp - DD M2A
Electrical - Big 3 - Stinger HPM 1/0 guage Wires, Optima Yellow Top Battery, 180/120 DC HO Alternator w/ MLA
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
refs: DC_Power_Kyle
it all depends. there is no answer other then build it and try
Well I was asking because I have my 2 Type Rs in a custom small ported box and they have punchy bass and hit lows really good but I never heard another system :( (Meaning sat in the car for a demo)
Component System
Sub Amp - DD M2A
refs: DC_Power_Kyle
some subs like bigger boxes and bigger ports. other like smaller enclosures. you need to check the specs on your subs to see what work best in
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
Yeah I know what you mean, just something I was curious about thanks for the answers though.
My box is a little bit smaller than what the recommended specs recommend but it still sounds great. :)
Component System
Sub Amp - DD M2A
refs: DC_Power_Kyle
Also power comes into play with size also. If you are running higher power then recommended you should stick to the box being on the smaller side. I think? Lol
say a sub handles 2000-4000 watts and needs 3-5 cubes. If you are throwing 4k watts to it, then it should be closer to 3 cubes right?
the best way to find out is to build and rebuild and rebuild till you find what works the sub only has a small factor to do with sound the most part is the enclosure i was told at one time that 15s are louder but wont be solid but that person was a fool it is all in the enclosure so good luck
my 15 played whatever i through at them...lows..mid and high bass...i was tuned around 37 so it was pefect for my various music. gotta have a good enclosure and good power to control the subs. with that they will sound as tight as a 12
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 1254 Guests (See full list)
