the port length/width was 15.5/2"..
maybe i need to go back to the 12's..
what about 1, level 4, 18? or is the box to small..
damn this is harder then it should be..
still way too small. in that space i would do a good set of 12's
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
wait, bigger box for 2, 15's or 2, 12's?
both actually imo
u need double the internal volume for 2 15s
2 12s would be ok in that, but would be better with more port area
Edited by Decaf
both actually imo
so, with the dimensions in the picture, what do you suggest i change the measurements too?
You could stick with the current dimensions and go with a single 15 but like other said you need more port area.
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
That all depends what 12's you plan to run.
Car - 99 Neon Sport
DB - 144.5 @ Dash.
2 lvl3 12's will do just fine just do a lil more port area and itll be plenty
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
