enemyofsilence Posted August 19, 2009 Author Report Posted August 19, 2009 so something like this and put it before the filter? http://www.automotiveconcepts.net/store/Fo..._medium=organic Quote Team Bass-Hz
Blue Posted August 19, 2009 Report Posted August 19, 2009 That is your Mass Air Flow sensor. You have to have the sensor in the middle of the air flow in the pipe. You just cant put it any where, it has to be in the main air stream. Instead of just putting the new filter on, you can get an aftermarket intake system. You can always modify the new intake system so you can have room for the battery. If you have to, just cut and splice new wires to make the sensor longer. I would suggest that you solder the wires, instead of butt connectors. That is what I would do. Just be careful and dont drive it. You can do serious damage with out the sensor connected. Good luck with it all. Quote formerly known as Blue86f150 its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies. Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive this sux camel dicks
enemyofsilence Posted August 19, 2009 Author Report Posted August 19, 2009 thanks all. im gonna put my stock back on and play it safe for now. does the adapter i put up work? i may go that route if it works... Quote Team Bass-Hz
Blue Posted August 19, 2009 Report Posted August 19, 2009 The adapter you put up looks like it will work. Quote formerly known as Blue86f150 its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies. Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive this sux camel dicks
enemyofsilence Posted August 19, 2009 Author Report Posted August 19, 2009 cool beans. imma order me one and put it in. once again, THANKS to all who helped by noobness on this!!!! Quote Team Bass-Hz
capalass23 Posted August 19, 2009 Report Posted August 19, 2009 its the intake air tepature its not much to worry about u could pull the sencor out of the origainal intake and set it there and ur check engine light wont be on Quote 95 WAGON BUILD FEED BACK
hertz hurts Posted August 26, 2009 Report Posted August 26, 2009 (edited) It's not the air intake temp sensor. It is the mass air flow sensor. The air intake temp sensor is the one thats on the back side of the corogated tube that the "new" air filter is clamped to. Mass air flow sensors have 4 wires going to them. Air intake temp sensors have 2. Edited August 26, 2009 by hertz hurts Quote
brewer_brewer Posted August 26, 2009 Report Posted August 26, 2009 that is a mass airflow sensor for sure. did you just replace your stock airbox with a cone filter and no intake tube? you know you are gonna loose power when it is hot right? Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
BulletInjection Posted August 26, 2009 Report Posted August 26, 2009 weird that they put a mass airflow sensor in there because a lot of people put aftermarket intakes in... Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
brewer_brewer Posted August 26, 2009 Report Posted August 26, 2009 ^^^seems normal to me. alot of cars are like that. and any good aftermarket intake will have a bong (not that kind, stoner) welded into it for that MAS to mount into. Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
