mbdblue Posted August 21, 2009 Report Share Posted August 21, 2009 also, you could contact DC Power or Mechman to see if they can make an alt for your car... Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
bigjsurdaddy Posted August 21, 2009 Author Report Share Posted August 21, 2009 Do you know what size the stock battery is? I can look it up at the office tomorrow and let you know what fits!i have no clue what size it is it's probably what ever the hyundai aonota has, because they are basically the same car. Quote Link to comment Share on other sites More sharing options...
bigjsurdaddy Posted August 21, 2009 Author Report Share Posted August 21, 2009 also, you could contact DC Power or Mechman to see if they can make an alt for your car...i contacted dc the other day. Damn, i didn't know that alts were that much. they had one that would fit my car, but they qwould have to do some work on it. it was a 270xp. Quote Link to comment Share on other sites More sharing options...
scottiej Posted August 21, 2009 Report Share Posted August 21, 2009 i have no clue what size it is it's probably what ever the hyundai aonota has, because they are basically the same car. Your car uses a group 124R battery from the factory. The measurements are essentially the same as the D3400 except the positive is on the opposite side. Many times you can drop a D3400 in that spot and use the 555 I-BAR kit with the starting terminals closest to the rear of the battery and the cables will still reach and work just fine Quote XS POWER Batteries, Chargers & Accessories 888-4XS-POWER Link to comment Share on other sites More sharing options...
bigjsurdaddy Posted August 24, 2009 Author Report Share Posted August 24, 2009 Your car uses a group 124R battery from the factory. The measurements are essentially the same as the D3400 except the positive is on the opposite side. Many times you can drop a D3400 in that spot and use the 555 I-BAR kit with the starting terminals closest to the rear of the battery and the cables will still reach and work just fine how much does a d3400 cost. i can only find d3100's. will a d5100 fit. Quote Link to comment Share on other sites More sharing options...
scottiej Posted August 26, 2009 Report Share Posted August 26, 2009 how much does a d3400 cost. i can only find d3100's. will a d5100 fit. The D3400 is $239... a D5100 will probably fit just fine. Quote XS POWER Batteries, Chargers & Accessories 888-4XS-POWER Link to comment Share on other sites More sharing options...
bigjsurdaddy Posted August 28, 2009 Author Report Share Posted August 28, 2009 The D3400 is $239... a D5100 will probably fit just fine.which is better the 3400 or the 5100r. also. when i run the second batt in the trunk, should i connect the positive and negative from the front batt or just the positive then ground the neg in the back to the frame. Quote Link to comment Share on other sites More sharing options...
BulletInjection Posted August 28, 2009 Report Share Posted August 28, 2009 which is better the 3400 or the 5100r. also. when i run the second batt in the trunk, should i connect the positive and negative from the front batt or just the positive then ground the neg in the back to the frame. The D5100r would work well because it should fit and the terminals are reversed so all your wires will hook right up to problems(if you need the reverse like stated above) Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
bigjsurdaddy Posted August 28, 2009 Author Report Share Posted August 28, 2009 The D5100r would work well because it should fit and the terminals are reversed so all your wires will hook right up to problems(if you need the reverse like stated above)thanks man, i'll look into that. do xs batts come with post or do i have to get my own. Quote Link to comment Share on other sites More sharing options...
BulletInjection Posted August 28, 2009 Report Share Posted August 28, 2009 (edited) thanks man, i'll look into that. do xs batts come with post or do i have to get my own.ummm I think some of the more expensive ones do? Sometimes I see them coming with posts but I think for the most part no.Antone else know? EDIT: if you need to know any specs http://www.4xspower.com/audiobatteries.asp Edited August 28, 2009 by BulletInjection Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
