yea just ground the wire(normally yellow) that your supposed to connect to your break.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
ok i found it
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
you can close this topic
tnx
What I did on my jensen unit is got a 3 position switch. One lead goes to the emgerency brake, the other lead goes directly to ground and the middle one goes to the headunit. It works fine and also, if a cop is near by, i can quickly switch it, so no ticket.
From the other forum I am on (the car club I belong to website)
Contura switches installed in dash for power door locks and brake override switch for dvd. The new one look very close to the factory ones.
Pushing it to the limits. Want more power.
the thing is i cant find my e-brake wire
you DONT wanna do that...if you do then you cant watch it while driving at all...that totally defeats the purpose...unless you plan to drive with your e-brake on
just ground the e-brake wire
NoFearX18 said:
lol, my e-brake dosnt work anyway
i just bypassed my HU, finally, grounded wire, then entered code, changed my setup, and it works now
