What does the "ah" stand for and what is its importance. Also I see the D5100R and D5100, what is the R's significance and how do these batteries differ?
D925
Weight Lbs. - 23.37
Weight Kgs. - 10.6
Length - 6.5 in
Height - 4.92 in
Width - 6.93 in
MAX Amps - 2400
Ah - 28
D975
Weight Lbs. - 25.0
Weight Kgs. - 11.4
Length - 7.83 in
Width - 5.2 in
Height - 6.22 in
MAX Amps - 1000
Ah - 35
Ah, is Amp hours.
Its a rating showing how long the battery will maintain a given amp draw.
For example, a battery with 1 Ah, can last 1 hour with a draw of 1 amp. or it can last half an hour with a draw of 2 amps, or it will last 2 hours with a draw of half an amp.
The 5100R refers to reverse I believe, it is the same as the 5100 but the terminals are reversed.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Ah, is Amp hours.
ohhh. Why would they make one reversed lol? So between the 975 and 925, the 925 would be better suited for a second audio battery because the higher max amps and no need for a high ah because the car will be running?
Edited by BulletInjection
they do reversed for cars that have terminals on different sides.
not all cars are the same
higher ah the better.
They make the reversed one to fit various types of cars and mounts.
Its hard to say what battery is better for you cause it depends on your needs and goals.
The 925s are easier to charge and also supply faster discharge, but are depleted much quicker.
I use D925s, but I have used 8) and am jumping up to 16 of them. The multiples give me the right amount of reserve I need for my setup and at the same time I have the instantaneous power for when I do dB Drag.
Edited by HHR Ed
Ed Lester
ShowtimeSPL Host
My old Build Log
8 is a sexy number, 16 is even better lol. I would just like to prevent my voltage from dropping so I was gonna have my yellow top in the front and 2 975's or 925's in the back.
this is the very reason C&D batts are popular.
only draw back is they are heavy as a bitch
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   0 Members, 0 Anonymous, 3766 Guests (See full list)
