thats why steeve mounts a 4kw amp on his box to kill it huh? lol
read the rest of my post. i was sayin i had read it but from my experiences it wasnt true
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
his box is also built like a brick wall :fyi:
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
haha, even my hood flexs a lil bit so i unno, amps should be fine tho
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
if i am mounting them flat in the trunk or anywhere with carpet then i use velcro.
^^just so i don't put holes in the floor or anything.
true, and probably aound high 150 decibels to the amp, regarless of how strong the box is, actauyl since steevs is a large box then what this guy is using and since hes more than likely not doing high 150's then there is no comparison, his amps will be 100% fine as long as he screws them down tightly, also rubber spacers are a good idea as mentioned above.
aslo if im not mistaken, steeves box is single layer 3/4" and some fiberglass...strong for an enclosure, deff...brick wall...not even close.
Edited by kbreudi
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
Vibration damage caused by mounting amplifiers on boxes is the #1 cause of amplifier failures. It will snap the mosfet legs right off. In some extreme cases where the board of a cheap amplifier isn't secured thoroughly inside the amp the board will actually flex and break. Do not mount your amp to the box unless there is absolutely no other option.
You think if the inside of your box is braced very well and has resin on the inside you wouldnt have to worry. Because i would think mounting my amp in/on my car it would flex worse in certain areas. I know that it is the #1 cause, just curious is all since i have my amps mounted on the box and i have window bracing and resin on the inside of my box.
Thanks
I once explained this to someone else like this.. You wouldnt staple your baby to the tires on your truck on the way to day care wwould you?
Team DC!
2005 F150 | Pioneer | Infinity Kappa 6x8's | MTX 3404 4 Channel | Q Logic Kicks | KNU | DC | AQ |
1998 Taurus | Alpine | Punch 5x7's | Rockford Fosgate | MTX | KNU |
  • Who's Online   0 Members, 0 Anonymous, 1979 Guests (See full list)
