I have been shopping around looking at HID conversions for my 'Prix recently, because the stock lights, well, suck. However, if I do get a chance to buy a conversion, I want to try and do away with the daytime running lights on my car from the factory. Basically whenever my car is on with the e-brake disengaged, my headlamps are on. No other bulbs, just the 9006s. Does anyone know if there is a way to bypass this?
EDIT because I can't spell.
Edited by ktownsdriftking
Too many projects, too little time...
I have been shopping around looking at HID conversions for my 'Prix recently, becaust the stock lights, well, suck. However, if I do get a chance to buy a conversion, I want to try and do away with the daytime running lights on my car from the factory. Basically whenever my car is on with the e-brake disengaged, my headlamps are on. No other bulbs, just the 9006s. Does anyone know if there is a way to bypass this?
It's the same on a lot of cars... Not required though, look at the pontiac forums. Search for disable DRL's, There's a relay that controls the circuit and there's also a sensor... I don't know if it's as simple as removing the relay on that car in particular though. You should be able to find some information on how to go about it. If the cars 06 and down, I can pull all of the wiring diagrams needed. Just let me know, on some cadillacs that I've disabled them on it throws a code for the sensor being bad. So there's some wiring modifications that needed to be done. Don't know if your car would be the same.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
look around the net for your car and also contact some local shops. I am about to do the same to my car, 09 jetta, but the vee-dubs run VAG-COM, and through that we can do all sorta of neat shit lol. more then likely someone/somewhere will be able to help you out alot more
like noted above, look around for a specific forum dedicated to your car type/make.
The Setup
2009 Volkswagen Jetta
2 Alpine SWR-1222D's in 2 seperate boxes tuned to 33hz
1 Kicker ZX1001.1
Stock 140A Alt
Stock speakers
check on www.gpona.com
it is a grandprix forum with some good info and some pretty kool guys on it.
Edited by shainemcconnell
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
What year is your car? If it's a 2000 or later then I'd suggest contacting BBEngineering and see if he can make up a harness for you. He's made one for my car but it's $75 and unfortunately there's no other way to get around it w/o throwing a code or messing up the function of the lights. If it's a later model like I said, our car's have alot in common so I feel your pain.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
my car is a 2002 GM and it was a simple as cutting a wire at the bcm and grounding it. No codes or problems for the last 3 years since ive done it.
DC.jpgDC POWER
I'm also curious as how to delete my daytime running lights for my 97 Blazer....they are annoying and I want to put HIDs in my high beams but cannot. CAn someone PM on how to do this, thanks.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
My YouTube Videos
