so im ripping out my equip today if it doesnt rain again, and the thought of having no bump is like .... ouch .... so i was thinking i could use the old box to make a quick single 12 enclosure sealed for sure ported if i have enough scrap, need less to say ill be powering a single PA Fubar 12" which is rated a 800rms i suspect that rating is a little high but anyway...
anyway im thinking the output of an amp is linear.. meaning to say
the 3000D is rated at 3000 rms @ 1ohm
so would that therorhectically sp? be 1500 @ 2, 750 @ 4, 325 @ 8....
anyway the sub is a D4 so ican wire to 2 or 8 ohms,
any help is appreciated
Thanks P4Killer :P
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
lol thanks, i never did look up how to dmm the gains, i guess ill give that a look see when the time comes
thanks bro
P4Killer :P
Setup:
Xs D3400/ Xs XP3000
the amps rated at 1500 at 2 ohm, you cannot set the gain for 800 watts, it just doesn't work that way.
the gain is for fine tuning your amp, it is not a volume control.
i say wire it to two and be easy on the volume. if it blows it gives you a reason to upgrade right??
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
a reason to upgrade, yea but w/o much funds due to college, and life... not really an option but if i did upgrade DD3515's for me :P
Setup:
Xs D3400/ Xs XP3000
idk honestly its a waste imo to wire that huge of an amp to 8ohms
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Its just untill i can finish the build in the back but that could be months from now so, ill set the gains at 2ohms unfortunately i dont just have another smaller amp to use for a small setup just to have some bump in da trunk.
Setup:
Xs D3400/ Xs XP3000
ok i got you. i completely misread. didnt realize you already had the equiptment
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
?? really
assuming the input voltage of the radio is low enough, like 3 volts and under, you can set the gain to put out only 800 watts.
so, if a radio put out a max of 3 volts. you could leave the sundowns gain at 0, since it has a max of 6 volt input, then youd get half power out of the amp. Isnt this right?
  • Who's Online   0 Members, 1 Anonymous (See full list)
