I take it its not a blow through right on the meter you may not have enough room for the wave to complete that what im banking on that setup in the vid did i think mid to high 130's and it was a 4th of the power im gonna be running and smaller subs so thats why im curious
Your right, no blow through for me, just coukdnt bring myself to cut it. So my 12's are ina 3.90 cube box. I have had other people tell me about the wave not being able to mature so it think I might be building a smaller box to give me more leg room but to also up my deebee's unfortunately I really like the way it sounds when it hits that really low freq. I have a comp in 2 weeks, its the VA state finals so im gonna meter it there & see what ido in SPL and drive by as well before I change the box.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
sealed = crap spl
thanks matt but hey while your reading any suggestions would be great you read the setup anything you think maybe different subs budget is important though i have to get the truck and have to have it fully done by next march SBN baby Btw maybe hope to see ya their steve and other fellow SMD members
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
I think you're going to struggle to bassrace a 139.9 with a sealed box.
well my only other option is to do the two of the re se 12's ported but i dont think that 3.5 cu ft is enough for them to breath with vent displacement and sub displace taken out of 3.5 it would probably more like 3 or 2.75 internal at that point is that big enough for them
Currently in car
you just do not have enough space to get something real loud. my box fa\or a single 12 is around 3 cubes (2.5 after displacement) the most id run in the is like 2 10's. but i also dont know how loud that would be either. any way u do it, itll be real hard to bassrace 39.9's with only 3.5 cubes and that 1606.
id go with one twelve and upgrade power. i know u got budget issues but it makes no sense to spend money and get something thats not wut u wanted. save and wait
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Yeah I know that but just a quick note you guys do realize that this is an suv not a trunk install just to make sure if that makes any difference.
Currently in car
look up the specs on them for min cube that they can work at 3 twelves in 3.5 cubes is not goin to work if you have space constraints you might want to consider a really good qaulity singe sub like one twelve or one fifteen youd would be able to bass race with the right sub and power in the 139.9
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
what sub i cant get another amp right now its not in the budget so i gotta stick with the BXi1606d what single sub can i use that will have enough sq for daily use and be able to put me in the 130 class my budget for the subs are between 300 and 400
edit my max box dimensions external are w=45.5 h=14 d=12 to 13
Edited by Jville140db
Currently in car
check out the soundstreamsplx 1000 rms or soundstream t5 or the re sx would work with that amp and with 3.5 cube after displacement
big 3 1/0
do you think that would give me what i want as far as spl and still sound good daily
edit all those subs are only around a 1000 rms and i should at least be able to put down 1400 to 1500 with all the electrical i will have
Currently in car
