If ya still have a problem with the Engine noise try taking 12 gauge speaker wire and wrapping it aroud the end of your Rcas on your hu and grounding it to you HU by attatching a ring terminal and attatch the ringterminal wuith wire to a screw on your hu
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
ok ill try that later on, its the first time its ever done it any other system that was in truck it never done it.could it be the amp?
  • 1 month later...
make sure your RCAs r plugged in all the way, I had noise in a car and thats what the problem was.
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
Now I know I heard today that the problem is the alternator
Is your RCA cables beside your power wire to your amplifier, the noise is the extra voltage coming from your alternator. when you start driving the alternator gets more power so it travels throught the power wire and it makes a reving noise
So you have to put your rca on the opposite side from the power wire ok
  • Who's Online   1 Member, 0 Anonymous, 1802 Guests (See full list)
