Marky Marks 25KW tahoe funky fresh rebuild (updates pg125)6-3-10
damn this almost done???..
david did some work!!..FAST work...haha..
cant wait to see this thing playing already!!
Looks great man, can't wait to see it all finished and playing... Should be the loudest non walled 4 18s in a Hoe out there once its all said and done.
Pioneer AVIC-N2
Man this build is now picking up speed!
And the wiring looks really clean, great job David!
But i do have a question, in the start of the build you said your going to do something for cooling the amps.
But now when i look at it they are going straight on top of each other......
Or is it now whit the wiring correct not a problem anymore.....
Maybe David is just stacking them and have to come back one month after the build is done to install diablo's! :spiteful: LOL
Have fun building the last bits!!!
We removed the plexiglass panels that were sandwiched between the amps and left the gaps to help the amps cool. We talked abou fans but were just out of time.
DAT amps would be sick.
Did you just not hav time to wait for them to come in?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
you could have put the plexy between the amps and routered out the center for air flow but still lit the edges with leds
build is getin'dun great work.
Routering the centers wouldn't have helped all that much IMO there still wouldn't have been any air flow acoss the heatsinks
The way they had it set up was all sandwiched tight. So even with it routered out in the center. The outside ring of plexi would have stopped air from flowing acrosss the heatsinks.
You probably could have done something like a 4"x4" piece of plexi at each corner. Plenty of airflow and it could still be lit up.
But whatevey you want, it looks dang good. Keep up the good work.
15.4" widescreen
What it does:
This is looking good david cant wait to see the end.....
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
I see no electrical tape or copper plumbing connectors. This build isn't being done right. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/ban.gif :crazy:
ddduuuuhhh,i dont know what he is thinking lol
I call dibs on the circle jig if your selling it. Just stuff that sucker in Davids bag when you send him my way..:D
lol aite,hey call me dude
the truck is looking good bro
i have 2 fly over 2 get a demo =)
dont be skeered :D
damn just quit for the day? what time is it there like 3:30?
yupp,i had to leave at like 1 cause i had to go to work and fuel an airplane,and then be here at 7am again this morning..gotta love it
oh lordy..i dont know about that..but we will see ..it should be perdy loud tho
yeah what david said,we took out the plexi so basically the amps are floating in mid air (other than the one on the bottom) so they should be perfectly fine now..especially being wired right.
sorta...but we can get them locally..ill probably still do the fans in the mids/high amp rack but sometime later after i get a break..that shouldnt be too hard. but we will see
that wouldnt really work in my application but its not a bad idea
