Well I have a stock alt that was rewound to put out more.. puts out around 210ish (used to putout 110) Anyways I have 2 12" DC lvl4 XL running @ 1/2 ohm off a DC PAI3000.1.... 2 sets of SS56.2 SS-Series 5 ¼" components running on a RF T400.4..........12v Optima 9003-151 Red Top 34R battery under the hood. Got 3 runs of 4ga running from the battery to a distribution block in the trunk with 5" peice of 1/0 running to the DC PAI3000.1. Anyways.. my voltage at idile is 14.24~14.26 ...... @ 3/4 (60/80) voulume the voltage drops from 14.26 to 10~9ish :shok: What do you guys suggest I do? with the 3 runs of 4ga it basically like having a bit larger than 1/0 wire. I know I need some batts in the back but I have no idea how many... Should Up upgrade my alt? its 210ish atm would the 40+ make any difference? Maybe get a dual alt setup? lmk your thoughts.
Edit1: forgot to mention I do have big 3 done with 1/0 wire.
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
I am kind of in the same boat as you. Im planning on upgrading to 2 batts and getting a dual alt setup. I was thinking of having my second alt dedicated entirely to my audio system. But then again I am running a lot less power I believe Roughly how many watts RMS are you running?
Current build:
Pioneer AVH-P3100DVD
Soundstream EQ
RF Components (5 1/4, 6 1/2, 6x9 x 2)
Two Fi-BTL 15's
One RF T1500-1bd Amplifier
T400-4bd
XS Power 608
XS Power D1200
Optima Yellow top 34
Soon to come:
Another RF T1500-1bd
HO Alt
1-6 more XS power 680
Team D.M.V
well the DC PAI3000.1 is rated 3000 @ 1ohm.. im running @ .5 so idk honestly... But I have the voltage set to 27.3 to accept at least 3000 watts (1500rms per sub)
get a big group 31 batt for the trunk
You think just 1 would do the trick? Any idea what brand? kenetic, xs?
Well IMO I would say just add another battery, (Either kinetic or XS, If you have any personal experience with any of them. But either way everyone says that they are pretty good)Or get another HO alt to replace your current one. One that puts out about 300 should work great for you.
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
If I can find a suitable 300 hHO alt would I need the 31 bat or nah?? Or vise versa.. Or should I just get both eventually so that there is no worrying about it later lol?
batts before alt.
im running almost 4k watts and have 2 big c&d batts with 3 runs of +/- and have almost no voltage drop...stock alt
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
You shouldnt have that low of an ohm load at the amp if you dont have the electrical to back it up. Get a battery bank, a Kinetik 2400 or Powermaster 3100 would work just fine. I bet if you rewired your shit to 2 ohms (assuming that the subs are both dual 2) then your voltage wouldnt drop as low. Just cuz you have multiple runs of 4 guage doesnt mean your shit wont drop, if you have that good of an alt, then with a big bat in the trunk you should be fine. So get a bigger battery and come back to us
my rebuilt stock alt did that when it was starting to die.... best of luck on just adding batts but it seems you need both... more batts and a new larger alt..
Full eclipse system is next on list.. soon to gut and redo the honda as new project/rolling buissness card :)
i miss the sound of those old school strokers on beast amps :(
  • Who's Online   0 Members, 0 Anonymous, 3609 Guests (See full list)
