I ended up getting 8gigs of this (and BTW, it is part of OCZ's top of the line Blade Series)
http://www.ocztechnology.com/products/memo...ge_blade_series
My thinking was, that (in theory) it should be able to do it's full job, at a cool, easy, 1.8 volts (the default voltage for most PC's anyway) without having to push anything. Yes, this memory can still be overclocked (pushed to more than 2 volts), but at least for now, I have no desire to do that anyway.
However, in my research, I'm seeing that even though most of the reputable companies do make Low Voltage Memory, they sure don't seem to sell very much of it. Why ? If a guy could get the same speed / power with 1.8 volts, why do they insist on 2.1 volts or higher ?
Of course no matter what the responses, I'm going to have to try the memory that I have on the way, and if it works fine, that's great. I'm asking more out of curiosity, and for future reference.
Much thanks,
Fish
that mem is pretty good ram, JUST MAKE SURE YOU FOLLOW THESE VERY IMPORTANT RULES IM ABOUT TO TELL YOU................Make sure you select the proper vdimm in the BIOS, DO NOT LEAVE IT TO AUTO FOR THE VOLTAGES. Auto will mroe then likely pump 2.0/2.1vdimm to the ram, which will create un-needed heat, and possibly lower the life of the product. ALSO, install a fan (120mm) over the ram some how, trust me, your mem will appreciate it..... (I think I already told you this as-well)
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Okay, will do.
Now, not to argue... But I had heard that my MBO will only kick out 1.8volts set to auto, and that I had to manually set it for anything higher. Either way, even if I used auto at first, I'll be sure to check that my memory is only getting 1.8 volts.... err maybe 1.85 ;) They say on the OCZ site that they still will keep their lifetime warranty at that voltage.
You know my tower (an Antec 900.2) is full of fans, right ? ....5 stock ones, and 2 more optional. I was thinking about getting the optional ones, just for the hell of it.
But your saying a fan directly over my memory will still be a good thing ? I'm guessing they probably don't cost very much anyway, huh ? $20 ?
Anyway, much thanks again,
Fish
Auto will set a different voltage on every motherboard. You could have 2 of the same boards and settings, and AUTO will set a different voltage 99% of the time, so who ever told you that, might want to rethink there knowledge. Go into BIOS and set mem to 1.83/5 volts, and proceed. When time allows, get your DMM out, and find the points on the MB where you can read the Vdimm voltage, and see if your board is undervolting, or over volting. And then set the voltage accordingly.
I dont care if you have 76 fans hanging in that case, get a fan over that ram (very important since your using 8GB's, and all the sticks are butt up next to each other) hang the fan from a zip tie (doesnt have to be pretty, just practical) and 120mm fans run as cheap as a few bucks, and thats all you need. A fan that throws out 45~ CFM (will be very quiet) and yet, effective.
Edited by newls1
Hey newsl1, okay, so manual settings it will be. Now if I could just get a list of the correct settings, for my purposes, with my memory and MBO....
No, I hadn't registered over there yet... But I have now. Unfortunately, I will have to wait (for however long) for a moderator to review my registration, before I will be able to post.
That was an AWESOME thread you posted the link to though. A BUNCH of those guys were using my same MBO, a lot of them already using that same memory.... a few guys discussing using 8gigs of it to :)
Only thing about that forum though, is it seems to me that most of those guys are building these outrageous fast, powerful PC's, just for the sake of building outrageous fast, powerful PC's... er, should I say, to post up these really amazing numbers.
Nothing against that whatsoever. Everybody needs to be crazy deep into something. I'm just afraid I might be coming at them from a whole different angle (the story of my life actually) when I walk in and tell them > I don't care about overclocking whatsoever.... I just want my 8gigs of OCZ Blade Low Voltage Memory to do 1066MHz, at 1.8volts, on this Gigabyte MBO, to be ultra stable, to stay cool, and to last a long time.
I can just see most of those guys yawning, and clicking 'next' :)
Hey about a memory fan, I will go look at those now.... But is their any particular one you would recommend, that will work well..... and maybe won't need "zip ties" ;) I don't care if it costs $15 instead of just a few.....
Peace,
Fish
Also, I guess you still ahvent regisitered over @ XS, if you did, you might have noticed this>....... http://www.xtremesystems.org/forums/showthread.php?t=224819
no, Just buy any cheap 120mm fan you can, it will work MUCH BETTER then those 20$ fancy POS memory cooling fan setups, trust me. And XS is a forum that has EVERY TYPE of person.....From CRAZY world record breaking people, to the 15 Y/O who doesnt know shit, so don't worry bro, you'll fit in great. I'll meet you over there once you can start to post.
Right on. Well soon we can add to that list > 45 year old who doesn't know shit :) LOL
Hey, after I asked about memory cooling fans, I kind of started to figure this myself.
Will be ordering a cheap 120mm fan for my memory + two Antec blue LED ones to put in the optional spots on my tower.... even if they don't do much.... just because :)
Peace,
Fish
