Guero3384 Posted September 7, 2009 Report Share Posted September 7, 2009 (edited) Im putting this up for a friend...... He was taking everything out of his truck and noticed this happened to his ground.... What would cause this everything was working fine when he took it out.... Edited September 7, 2009 by Guero3384 Quote Check out my build http://www.stevemeadedesigns.com/board/ind...mp;#entry717600 4 12" Kicker L7's 1 zx2500.1 Kicker Amp 1 zx650.4 Kicker Amp All Kicker 1/0 Wire Headunit Jvc Kw-Nx7000 3 sets of 6.5 Image Dynamics CXS6 series Link to comment Share on other sites More sharing options...
Guest Posted September 7, 2009 Report Share Posted September 7, 2009 only thing that comes to mind is a cut somewhere along the wire and shorted to a piece of metal. + no fuse. Quote Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted September 7, 2009 Report Share Posted September 7, 2009 (edited) Loose Ground, it was probably arcing which caused it to melt, had the same thing happen to a fuse holder of mine, the wire wasnt the tightest and would arc every once in a while, and I didnt notice anything performance wise, didnt find out about it until I saw it. Edited September 7, 2009 by CaptainzPlanetz Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
Namosh Posted September 7, 2009 Report Share Posted September 7, 2009 I'd say it wasn't making a good connection at the amp. It was essentially an electrical bottleneck and caused it to get really hot. Quote My Ram Quad Cab Blow-through Link to comment Share on other sites More sharing options...
Guero3384 Posted September 8, 2009 Author Report Share Posted September 8, 2009 (edited) it being loose was the only thing he could think of but wanted to post it up on here to make sure it wasnt something else and just to get some ideas. the amp was working fine when he took it out. the wire strands fused themselves to the amp i guess because it got so hot. can he still use the amp and just try to remove and clean out all the wire in the terminal or does he need to get a new one put on the board before he reinstalls it? it looks worse in the picture than it really is its just the plastic around it that melted and theres not that much wire in there that hes going to have to try to get out. Edited September 8, 2009 by Guero3384 Quote Check out my build http://www.stevemeadedesigns.com/board/ind...mp;#entry717600 4 12" Kicker L7's 1 zx2500.1 Kicker Amp 1 zx650.4 Kicker Amp All Kicker 1/0 Wire Headunit Jvc Kw-Nx7000 3 sets of 6.5 Image Dynamics CXS6 series Link to comment Share on other sites More sharing options...
zfrerichs Posted September 8, 2009 Report Share Posted September 8, 2009 the amp is still good just clean it up Quote Roseville, CA Link to comment Share on other sites More sharing options...
CR Boom Posted September 8, 2009 Report Share Posted September 8, 2009 Find a drill bit the size of the positive and use it ot clean out the negative... Loose screw for shur. Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's Link to comment Share on other sites More sharing options...
Boon Posted September 8, 2009 Report Share Posted September 8, 2009 Find a drill bit the size of the positive and use it ot clean out the negative... Loose screw for shur. Just use a really slow setting on your drill And remember to take the grub screw out first Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
zfrerichs Posted September 8, 2009 Report Share Posted September 8, 2009 i would try like a mini wire brush from a dremel or somethere tip on a dremel i wouldnt try the drill Quote Roseville, CA Link to comment Share on other sites More sharing options...
Guero3384 Posted September 8, 2009 Author Report Share Posted September 8, 2009 alright cool thats what he was hoping to hear. yeah i dont know about a drill on it but hes got a dremel so ill let him know to try that. appreciate the help Quote Check out my build http://www.stevemeadedesigns.com/board/ind...mp;#entry717600 4 12" Kicker L7's 1 zx2500.1 Kicker Amp 1 zx650.4 Kicker Amp All Kicker 1/0 Wire Headunit Jvc Kw-Nx7000 3 sets of 6.5 Image Dynamics CXS6 series Link to comment Share on other sites More sharing options...
