Hi this is my Current install im pretty happy with it but i am now building a wall!
Us amps usa-6000 (not a double d!)
Specs from USAmps site
Two Channel Class AB Amplifier
Total Power Output: 6000 Watts RMS
3000 Watts x 2 into 1 Ohms
6000 Watts Bridged into 2 Ohms
THD at Rated Power: 0.1%
Signal/Noise Ratio: >105dBA
Frequency Response: 5Hz-50KHz
Damping Factor: >2500
Fuse Rating: 900 Amps
Dimensions:
114mm / 4.50in High
229mm / 9.0in Wide
629mm / 24.75in Long
Weight: 14.52kg / 32.00lb
Variable 24dB Low-Pass Active Crossover
2 dd9512's
CDT audio CL62's
powerd by
Us amps TU-600 Hybrid tube amp
Edited by The Junglist
That amp looks massive!!! How do those cdt's sound cause ive been thinkin bout a set of mids and highs for up front
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
NICE amp, that thing is a beast
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Thanks!
For 2 12s its pretty brutal :hairtrick:
The cdts sound really nice, The trebble is in no way harsh evern at high volume but it still remains super detailed and so clear!
Im not sure about the tube amp and vibrations i did wonder myself but i figured hey it was designd for a car so must be ok lol, my box is pretty dam solid and dosent appear to be much vibrations on the amps.
Im currently building a wall same amps but this time either 2 18s or 4 15s.
  • Who's Online   0 Members, 0 Anonymous, 1292 Guests (See full list)
