Building an amp rack..?
Gearstix
I bought an Audiopipe AP3000.1D.
I was told by the seller that these amps don't like to be hot (well, what electronic device really does).
Although the climate in Texas is a bit hotter than the climate here in Canada...
He recommended that I build some sort of fan cooled amp rack.
I'm not quite sure how to do it.. any suggestions. I like the idea and I can weld.. so a metal rack is a possibility, plus I can get various sized PC fans.
I would do one similar to how Meade is doing his. Go take a look at his build log because its a simple idea but it will definitely keep his amps cool.
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
Go to newegg.com and look at the computer case fans.
http://www.newegg.com/Store/SubCategory.as...;name=Case-Fans
Here you go.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Here you go.
Thanks for the link though.
I have my AP30001D's fan cooled, VERY EASY TO DO. Go to home depot and buy a sheet of LEXAN to make a clear amp cover on the bottom (replacing the metal cover that is currently on the amp) Take that cover you just removed, and trace its outline on the sheet of lexan you just bought. Cut it out, and test fit it, should be perfect. Then get a 120mm (convert to inches) hole saw, and drill yourself out 2 holes per amp (I will have mine 1 on each end) and install your 120mm fans that you can buy on newegg for just a few bones each. Very easy mod, and should provide some usefull life into this amp, as apparently they do run warm/hot. I wouldn't know yet, I still havent even put power to any of mine.....
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Would that void the warranty? I don't think I have any, anyways.
I don't have the amp yet. But thats a good idea. No fans in the way.
I have some lexan or plexi kicking around. I may make one out of diamond plate or sheet if possible.
Where did you get the power for the fans? The amp turn on?
Could you post up some pics by any chance? Thanks.
I posted the pictures of the amps with the plexi bottoms on, just didnt have the fans done yet, but use your imagination, you know what I mean.....I'll find the post, and insert the link in this thread when I find it......BRB
  • Who's Online   0 Members, 0 Anonymous, 659 Guests (See full list)
