BassHead7 Posted April 16, 2007 Report Share Posted April 16, 2007 so i just bought that DEI 2400d Directed amp. and now it dont work. it was workin great. but one day i turned the car on and it didnt work. it lights up n turns on but it dont push the subs on at all. ive tryed messin wit Everything. and i hooked all the wires up to my other amp and subs work great. wut do yall think could b wrong? Gota have my rear view shakin and my seats vibratin'. (2) 12" Diamond D3 (1) DEI Directed Audio 2400D (1) Kicker L5 15" (1) Rockford Fosgate P5002 (2) 12" Fosgate P2's (2) 15" Fosgate P2 ^^Not all hooked up at once, i rotate. Its all i got.^^ Link to comment Share on other sites More sharing options...
mtxcivic07 Posted April 16, 2007 Report Share Posted April 16, 2007 so i just bought that DEI 2400d Directed amp. and now it dont work. it was workin great. but one day i turned the car on and it didnt work. it lights up n turns on but it dont push the subs on at all. ive tryed messin wit Everything. and i hooked all the wires up to my other amp and subs work great. wut do yall think could b wrong? your inputs on the amp are fried. you need to get it repaired. also check to see if you wired it too low for the amp so it wont happen again. b/c i had the same thing happen to one of my old amps b/c i wired it at too low of an ohm load. 18's in a wall to come....Its not all about the posts....check the member #... Link to comment Share on other sites More sharing options...
Chris Posted April 16, 2007 Report Share Posted April 16, 2007 He doesn't give a fuck. J/K! 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR. Link to comment Share on other sites More sharing options...
BassJunkie Posted April 16, 2007 Report Share Posted April 16, 2007 Also try the ground, my buddies ground was loose and we had the same symptoms. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
BassHead7 Posted April 16, 2007 Author Report Share Posted April 16, 2007 its nothing to do with wires though at all becuz i hooked the exact same ones up to my other amp and it worked fine. how much is it to get that repaired. and the speakers are single voice coil so im not running them at low ohm loads. Gota have my rear view shakin and my seats vibratin'. (2) 12" Diamond D3 (1) DEI Directed Audio 2400D (1) Kicker L5 15" (1) Rockford Fosgate P5002 (2) 12" Fosgate P2's (2) 15" Fosgate P2 ^^Not all hooked up at once, i rotate. Its all i got.^^ Link to comment Share on other sites More sharing options...
